OK....i'm new here....so any technical talk about hardware and software goes completly over my head. I have a standalone dvd recorder...but am not overly impressed with it...but anyway, i'm looking to buy a computer dvd burner drive, but as there are so many to choose from I was looking for some reccommendations, These are my specifications:
I'M in the UK so it would need to be on the market here
Multi-regional playback (& recording if possible)
Must Be Able to disable the macrovision (as I can on any of my other players)
And be compatible with basic burner programs.
Any help with this would be great!
Thanks!
I would recommend either the dual format sony DRU-510A or the new dual format Pioneer A-06. If you don't need dual format the Pioneer A-05 can be picked up pretty cheap now.
great..thanx....just one thing, does dual format allow you to record on double sided discs or does that means something else
Dual format means that you can record to both DVD-R/RW and DVD+R/RW
Well i've just looked at some prices and i'll think i'll go for the Pioneer A-06. I had a look in the hacks section of this site could find any...is there one to turn off the macrovision and enable multi-region playback?
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 17:02 -
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
