Eny comments about this drive?
Results 1 to 9 of 9
It's very loud when reading discs. Firmware freezes my comp with every version I've flashed. (but now Nero does read 8 mb cache, but what does it matter, it has burn proof technology.) I wish I could use Roxio but the dd0203 drive isn't supported (not DVD anyway) Eject button is small and opens/closes in slow motion. I don't think you can vertical mount unit either. Drive door could use some foam around it. I'm using B's Clip for DVD+rw's with full format option (roxio only has quick format option)
The HD-Burn feature doesn't work on mine. If y'all get it running let me know what you did. I upgraded B's to v5.23 and firmware to 2.09, still no success. I hate B's, but Nero doesn't support this drive yet.
Other than the HD-Burn, which I will probably never use, it seems fine. No noise problems like you've described, fish. Of course, you couldn't hear anything over my cooling system, anyway!
I have noticed one thing. I can't get any sound from audio CDs through my soundcard. The MMC cable is connected and all inputs are unmuted in the mixer. What obvious step have I missed?
I can burn fine with Nero, the new version 5.5.10.42 and the version before that. Nero even supports the HD burn feature, but you have to use supported CD-R media. Audio plays fine on through comp speakers. Nero Mix seems to be able to play audio through the IDE cable.
Supported CD-R? Hmmm, I didn't realize that media had to support this feature. That may explain why it's gives the error "Head Select Fault" but can still burn a regular CD or DVD...
Enlighten me. What media supports HD-Burn?
Still no audio. Must ponder further...
Hi,
Yesterday i installed my OptoRite DVD writer. The instalation was fast and easy.
I burned an home made video on a DVD+R and MP's3 on a CD-R.
Works great.
Also, no particular noises....
I Am Happy!
Oren M.
