ok i converted an svcd from pal to ntsc useing main concept mpeg encoder, all seemed to be going ok, i did notice that the ntsc files where about 10mb larger than the orginal pals, no big deal i thought.
I fired up svcd2dvdmpg+ and started to make my dvd
the end resualt was a 5.49GB dvd i dont understand this
the movie is only 3cds @ 850mb (or so) each
the other thing that i noticed is that svcd2dvdmpg+ took forever to finish over 2hrs
what did i do wrong??!
i did this btw becuase i wanted to burn this movie off to dvd of course for play back in an ntsc only dvd player
thanks in advance
It sounds like you chose DVD as the mpg type instead of SVCD. Just use one of the many encode proggies to bring it down to size.
well the output is set as follows
MPEG TYPE: SVCD
STREAM TYPE: PROGRAM (VIDEO+AUDIO)
VIDEO MODE: NTSC
AUDIO MODE: LAYER 2
shouldnt the layer only be 1 for an svcd
and if it out put as a dvd it shouldnt have
i set it for svcd i tryed it 3 times (1 on each file) -
layer 2 is the audio encoding which is indeed layer 2 mp2.
Maybe you can try Elementry Stream that is the setting i always use in tmpgenc. or use tmpgenc to encode. -
are you talking about in mainconcept or svcd2dvdmpg+?Maybe you can try Elementry Stream that is the setting i always use in tmpgenc. or use tmpgenc to encode.
cause mainconcept doesnt offer that spacific setting, and when i do that with svcd2dvd
it makes 3cds @ 2gigs each
also, i tryed useing dvd2one to compress the files and that didnt work
the main thing is why is svcd2dvdmpg+ making these files soo big -
i told you i didn't know mainconcepting. So i couldn't have know that option wasn't there. You can't do it in svcd2dvdmpg+ cause it needs finished mpeg-1 or mpeg-2 files.
Why not try to do a little bot in tmpgenc and run it through svcd2dvdmpg+ If it gets much bigger like your files now then i haven't got a clue. If not i think you better use tmpgenc to encode divx -> svcd. See guides section for guides..
Yf -
if you said you didnt know mainconcept i didnt see it, its not in this post, i did however use tmpegenc (thank you for the suggestion) and that did work, still dont know why mainconcept didnt work but oh well so is lifeOriginally Posted by yf2001usa
thank you for the help
With Nero 7 Ultra, why are imported dvd files so big?
By wisny in forum EditingReplies: 13Last Post: 13th Mar 2011, 08:38 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
files to big/or sound to fast
By silvabak in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2008, 12:17 -
cannot seek in big (>2 GB) XVID files
By adwiel in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 01:41 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05
