I want to put some jpeg still pictures in my DVDs. My avi captures are done at 720/480 for a 4:3 TV. Since 720 divided by 480 is 1.5 and 4 divided by 3 is 1.33 I am a confused about what resolution aspect ratio my Jpegs should be to be accurate. I am using mediastudio pro and it will automatically make my pictures be completely on the screen but this does not mean that they are geometrically correct.
Try this thread for some info:
https://www.videohelp.com/forum/viewtopic.php?t=164685&highlight=menu+still -
Thanks. That thread has some good information. I guess I will try to find the NTSC filter in photoshop tonight. I think I need to make a circle and then see it on the tv and then make sure it is still a circle on the tv.
You might also want to check out these links:
http://www.mir.com/DMG/aspect.html
http://www.lurkertech.com/lg/pixelaspect.html
Building mpeg from jpegs aspect ratio problem
By npokonu in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2009, 03:44 -
Change Aspect Ratio of DVDs
By EnigmaXtreme in forum Authoring (DVD)Replies: 15Last Post: 9th Jan 2009, 23:17 -
Aspect ratio questions with Sony Vegas & Instructional DVDs
By RockWood610 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jan 2008, 17:22 -
Aspect Ratio
By kolias in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 09:28 -
Aspect ratio??
By frednufc in forum Video ConversionReplies: 1Last Post: 14th Oct 2007, 16:11
