All DVD’s start to play then fail when the DVD menu wants (starts) to appear. This is true from both DVD’s in the DVD Drive and from *.vob files from the hard drive. In the case of the VOB files (extracted with ‘SmartRipper 2.41’ just fine) it ONLY fails on the first of the set that includes the interactive menu, otherwise all the other *.vob’s play just fine. I was ripping and converting files to MPEG-2 all dame weekend using TMPGEnc.
This happened with all DVD Players including Win Media Player, WinDVD v4 and a couple of other bundled players with DVD’d. All respond in the same way.
Tried disabling hyper threading, fast writes, write combining and reduced hardware acceleration and so on. Tried different video drivers as well (Cat 3.4 and 3.5 drivers for WinXP).
WinXP reporting errors:
WinDVD MFC Application
AppName: windvd.exe AppVer: 4.0.5.43 ModName: gpiproxy.dll
ModVer: 4.0.5.43 Offset: 0013e775
Windows Media Player
AppName: wmplayer.exe AppVer: 9.0.0.2980 ModName: iviaudio.ax
ModVer: 4.0.5.43 Offset: 00004b85
My friend with a very similar system is having the very same issues.
Abit IC7
P4C
Radeon 9700pro
Dual Channel Memory (2) 256Mb sticks of PC3500
Pioneer 16x DVD
WinXP sp1
http://www.abxzone.com/forums/showthread.php?threadid=33543&highlight=Pioneer+DVD
PowerDVD for XP (V4) is the only player that works!
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 15:54 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 09:03 -
how to format cloned system hdd with winxp
By deejay.2001 in forum ComputerReplies: 4Last Post: 22nd Jun 2008, 07:17 -
PowerDVD XP 4.0 Won't Play in Updated WinXP
By SLK001 in forum Software PlayingReplies: 4Last Post: 14th Aug 2007, 11:05 -
computer freezes, won't allow WinXP install
By iThinkYouBrokeIt in forum ComputerReplies: 15Last Post: 13th Aug 2007, 18:07
