I just bought 20 disk TDK 4X DVD +R but I just read the warning label on this bundle DVD. It said that this media is intended for use with 4x speed DVD +R drives. Using this media with drives rated to record at 2.4X maximum speed may result in recording and reading error, and/or may result in damage to the data." I just want to know if anyone in here has successfully burnt this media with a 2.4X recorder. I just want to make sure if I can burn this media with a 2.4X burner before I open the products.
Thanks for your inputs.
Good question, I was just about to buy some on sale. I have a Sony DRU 500A, anyone know if that will work?
Get the firmware update for your burner. Check out www.dvdplusrw.org, or the drive's maker's website for an update.
With 2x max Pioneer drives, using 4x media will/can harm the drive without the correct firmware.
+RW drives say the disc will produce read/write errors, and may harm the drive.
The Sony500 is a 4x burner, doesn't apply here.
Media Express 3.0.3 Question?
By Darkensteele in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2011, 05:47 -
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 10:54 -
First time using HD media question.
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Dec 2010, 09:34 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 14:10 -
Question about + or - DVD media
By OzarkBaby in forum Newbie / General discussionsReplies: 7Last Post: 16th Dec 2007, 19:19
