i have 3 svcd files i joind them using the new version of Tmpgenc
and i tryed SVCD2DVDMPG AND SVCDDVDMPG+
and i get this
---Filedetails
D:\movies\Thehulk\Newfolder\Hulkfull.mpg is not a valid mpeg file
This has only happened to me once ,is it because i joined 3 svcd files??
First, if the movie you name in your post is a movie that's still in the theatres, delete the name from your post otherwise you will get a warning from a moderator. When you open the mpg file in svcd2dvdmpg navigate to the folder that contains the movie, not to the mpg file itself. Thus in your situation you would navigate to "new folder", not the movie.
if you did go to the folder. use virtualdub mpeg version to check if your mpg is vallid.
Yf -
ToXMaNGuest
Yes, it is because you joined 3 SVCD files. What is the size of the resulting file? I bet it's over 2Gigs. There is a limit on the size of SVCD MPEG file. I found out the hard way too.
>x< -
yes its 2.2gigs ,is there anyway around this so i can combine them and put it on a dvdr
valid ts file
By qman7112 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 15:35 -
Is 704x480 with a 16:9 DAR valid for DVD?
By Anonymous344 in forum Newbie / General discussionsReplies: 136Last Post: 5th Jan 2011, 14:11 -
.EXE is not a valid Win32 Application...what to do? :(
By drunkenboxer in forum ComputerReplies: 10Last Post: 27th Feb 2009, 12:51 -
Ironic: AVCHD is not a valid format to edit?
By tmw in forum EditingReplies: 5Last Post: 25th Dec 2008, 22:22 -
Not a valid avi file and Unable to insert......
By tommyboy9495 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2007, 22:11
