When trying to rip a Region 1 DVD using DVD Decrypter (Sony DWU-10a firmware flushed to Sony DWU-500A with 1.1d firmware update) I got the message 'Brute force cracking failed ... There were no vulnerable blocks'. I was trying to rip all files in the file mode. Other Region 1 DVDs have ripped without problems.
Can anyone help me with a solution to this problem?
Thank you
DoctorJ
Hello DRJAZZ123
This is just a wild guess, but could it be that disc was actually NOT protected, and DVD Decrypter was expecting a protection of some sort?
Or maybe it's a type of protection that DVD Decrypter cannot cope with.
Have you tried ripping it with Smart Ripper or DVD Shrink? -
Try SmartRipper instead in file mode. I'd got that same error with DVDDecripter once, and Smartripper read the complete DVD without a hitch.
George -
There is a reason why there are 4 different CSS cracking methods in the settings... if one doesn't work, try another!
strange because I have done 200 successfull DVD's and have not had to switch any settings in dvd decrypter, I am almost positive that I have got this error before and just switched to a different dvd rom drive.
Thanks alot,
dreadogg -
Originally Posted by DRJAZZ123
do you have a separate DVD-ROM drive that you can use for ripping purposes (and playing DVDs, as well)? these DVD-ROMs are cheap...16x for around $30 or less. you prolly don't want to wear out your dvd burner anymore than you have to by using it to rip the DVDs. if your dvd burner breaks down, it's gonna cost you alot more than if a cheapo DVD-ROM breaks down. btw, i've heard that DVD burners don't seem to rip as fast or as well as regular DVD-ROMs....so far it's been the case with me (pioneer a04 vs. artec 16x DVD-ROM)
Cracking Philips DVP3345
By ringosshed in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jan 2013, 07:57 -
Cracking Region Code for LG HT304SLH
By YoungFrankenstein in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Apr 2010, 09:17 -
Is Microsoft Cracking Down on DVD Ripping?
By rkr1958 in forum Latest Video NewsReplies: 41Last Post: 13th Feb 2008, 08:49 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 13:54
