can anyone explain this error, concerning cinema craft encoder?
fexp_close()failed***could not close the file c:\movie\encoded_video_cce_ntsc.MPV
the handle is invalid
windows error code 0x6 6]
I am trying to convert to SVCD.
the file i am importing is divxmpg4 v3.
Iam using cce as i belive it is the best.
i also have another format to convert to SVCD it's called XVID.
If you can solve my above problem will this one be the same.
It also takes from 6 to 8 hours,i belive it should only take about 3-4
MANY THANX for your time
and remember
PLAY UP POMPEY
POMPEY PLAY UP
Results 1 to 1 of 1
