Can anyone tell me the easiest way how to join 2 wav files together, and what program to use, i have goldwave and soundforge, but can suss it out properly.
Many thanks
Hercules Man
Goldwave is a great utility (although I prefer Cool Edit).
Here's what you can try. Using Goldwave, open up both WAV files. Select All (CTRL+A) of the one WAV, and Copy (CTRL+C) the selection. Next, goto the other WAV window. Goto the Edit up top, and select PASTE AT>END.
That should do the trick. Then just save I guess.
Hope it helps, peace."The Driver is You!" -
Just tried that but it does the same as soundforge did, it placed the file i selcted at the beggining of the file i pasted to, and not to the end, so i had a bright idea, i did it the other way round, pasted the first half to the second half, and still the same. wrong way round,
Anyone any ideas
Hercules Man
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
joining vob files
By natty in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2010, 12:04 -
wav files
By BLSAMPLES in forum AudioReplies: 2Last Post: 17th Jul 2009, 14:52 -
Help joining wav and wmv files with Avisynth
By jjones3535a in forum EditingReplies: 2Last Post: 7th Jan 2009, 18:09
