i have a vhs tape i transvered to avi to get best quality.if i make it into a mpg2 file will the quality be better than if i just did it as an mpg2 file in the first place.it just i want to get rid of the blocking effect and maybe use a filter of some sort.the film is in black and white
The general rule of thumb is to capture in the highest resolution and bitrate you system can support to uncompressed avi video (or with a 'lostless codec' like huffyuv'). Edit as necessary. Then encoded to a a lower resolution/bitrate as/if needed.
Generally speaking capturing directly to MPEG2 does not give as good quaility as capturing uncompressed then encoding with a good software encoder.
However, IMHO most VHS source tapes are of such poor quaility that to save time I just capture to MPEG2 at 352x480 and author. The quaility is lost is not worth the extra hassle _IMHO_, YMMV.
mpg2 color correction?
By Mike99 in forum RestorationReplies: 74Last Post: 25th Oct 2011, 23:31 -
mpg2 aspect ratio
By Ogilvy in forum EditingReplies: 2Last Post: 26th Jul 2010, 14:55 -
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 18:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 15:05 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 18:33
