    Mar 2003
    Tacoma,WA
    I captured a video from my miniDV into Premiere6.
    I believe it made an avi file.
    The problem is when I try to open it in TMPGEnc, it doesnt recognize the format.
    Am I doing something wrong?
    Is it not an avi file?
    Oct 2002
    Huntsville, Ontario, Cana
    I seem to recall reading about a plugin that allows the output of Premiere to be read as the input of TMPGEnc.
    Doing a site search for "Frameserving" I found this giude:
    http://www.videotools.net/guides/guide_premiere_tmpgenc.php
    Hope this helps.
    Will
  3. After you captured, did you place your file in the timeline and then go file - export timeline - movie - then create the avi? Or did you just capture close Premiere and try to take that file into TMPEGne?
    Mar 2003
    Tacoma,WA
    I just tried to load it from my computer after I created the timeline/file.
    I see what you mean by going through Premiere.
    Ill give it a try.
