Hi I want to burn an Audio CD that can be played 90 minutes... is there any method to create a lengthy audio CDs. 900MB/99min CDs are available in market. But in my CD burning software supports only 80min on these CDs. May I need to upgrade my CD writer/burning software?
Thank you for any replies
Is there any free software that will let you split up tracks?
I would like to take a CD with one long track and split it into 5min tracks.
Also I ripped commentary from a DVD and want to play it in my car.
It is now in a one long wav format. -
Try Goldwave.Originally Posted by Rond66
Nero can do this too though I suppose that it isn't free...Originally Posted by Rond66
The only truly free alternatively would be to make a CUE/BIN image of the existing audio CD (or rip it to one wave file) -- can both be done with completely free software -- and then edit the cuesheet to manually create additional tracks. Then burn with CDRDAO.
If you own Nero, I suggest you use that instead.
Regards.Michael Tam
w: Morsels of Evidence
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Software to create mp3 audio CDs
By 1234567 in forum AudioReplies: 5Last Post: 5th Jul 2011, 20:52 -
Burning engine for audio CDs
By dadrab in forum ComputerReplies: 13Last Post: 29th May 2008, 16:23 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 18:50 -
Help with DTS 5.1 Audio CDs
By ontherocks in forum AudioReplies: 4Last Post: 20th Aug 2007, 08:22
