Hello,
I would like to copy the AC3 files on a DVD to my hard disk.
Can this be done with Smart Ripper? If so, could someone point me to a guide or set of instructions?
Thanks for your help,
Tom.
I don't know all of the options in smartripper, but if you can create a set of vob files, you can pull the ac3 out with vobedit. It's called demuxing.
You can do this from smartripper thou and save a step:
1) Open DVD of interest w/ smartripper
2) Select the title set with the audio of interest
3) CLick on the 'stream processing' tab
4) Click 'enable stream processing' box
5) Select the stream/s of interest and hit de-mux (note you have to select each stream and hit de-mux one at a time, it's not a univerisal command)
6) Run
This will rip the dvd to the HD and de-mux to create an ac3 file of the audio (you can also demux the m2v-video or subtitles, etc if you wish).
Ripping A DVD: Can I Just Copy The Files Myself?
By SetoTitan in forum DVD RippingReplies: 8Last Post: 22nd Mar 2012, 12:03 -
Ripping a Track Out of an AC3 File?
By SLK001 in forum AudioReplies: 0Last Post: 18th Mar 2011, 00:10 -
Ripping AC3 Stream from a DVD File
By Surya in forum DVD RippingReplies: 5Last Post: 27th Sep 2010, 09:22 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
Ripping 50 DVD chapters to individual files
By indijay in forum DVD RippingReplies: 2Last Post: 16th May 2010, 02:05
