  1. i am trying to convert mov. files over to mpeg1 format. the mov. file begins to convert for 1 second of actual movie and for about 10 seconds then TMPGE freezes. is there a way to correct this???? also, i have some flash.exe files. is there a way to convert those into mpeg files????
    THANKS.......
  2. Try radtools (and if necessary total recorder). Take a look at:
    http://www.vcdhelp.com/mov2avi.htm
    Strongly recommend installing the huffyuv codec and using for the output avi (uncompressed file will be huge other wise).
  3. Thanks Alot Vejita-sama. I'll give it a try.....
