After compiling my dvd I end up with no audio. I have draged the film and audio to relevent palces, anyone any ideas why the output has no audio
Results 1 to 10 of 10
DVD-Lab adheres strictly to the DVD standards. it requires ALL audio to be in the same format. They ALL have to be either PCM or MP2 or AC3. You can't mix and match.Originally Posted by chopper20
Other DVD Authoring programs try a quick conversion of audio while authoring. The results are mixed.
If you ensure the MPEGs you give DVD-Lab are uniform in format, the result is an excellent DVD.
Also, stay away from version 1.2.1 it has lots of bugs. Go with 1.15 or 1.2--
Will -
I am using just one piece of digital video captured and edited in premier and converted by TMPGEnc. I can hear the audio wwithin dvdlab but not once it has produced the dvd
That is strange, because DVD-Lab has no audio preview capabilites....Originally Posted by chopper20--
Will -
Double clicking the file in the Assets window is the same as double clicking in Windows Explorer, it calls up whatever program you have set to play audio. It has nothing to do with DVD-Lab.
If DVD-Lab has no problems demuxing your clip, then set DVD-Lab not to demux. Then load the assets again and create the DVD that way.
No need to Demux and mux again....
You only do that when you are not sure about your assets being compatible.--
Will -
When you start DVD-Lab, before you load any assets, click "Projects" - "Project Properties" - "Options".
Under "Non Elementary MPEGs" - You can change it to "Always Ask" (so you have a choice) or "Use without Demultiplexing".
If you click the "Advanced" tab, you will see where it mentions audio associations.
Hope this helps.--
Will -
Did you tried audio button from your remote? Try changing audio format and see if it works. I had the same problem and end up making dvd with other program. - B
The problem turned out not to be with dvd-lab. I had installed power dvd5 and for some reason it not playing the audio. Once I reenstalled power dvd 4 everthing worked ok (playing off hard drive). Thanks for the help though
How to create an Audio-Only DVD in DVDLab Pro (IMPROVED)
By GordRocks in forum User guidesReplies: 26Last Post: 15th Jun 2023, 07:55 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 21:38 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 10:00 -
How to create an Audio-Only DVD in DVDLab Pro (PART 1)
By GordRocks in forum User guidesReplies: 28Last Post: 7th Oct 2007, 01:53
