I have tried a few programs like PowerVCR II or Move Factory II with the DVD+VR Standard.
When I try to capture something from the tv-card there is always an error-message that says there is not enough disc space or an unkown error happend. It doesn't matter which program I use, caputuring directly to the SVCD or DVD format never works!
But capturing to the VCD format always works - I don't understand that. All programs can capture directly to the vcd-format, but if I select SVCD or DVD nothing works anymore.
Do I need some codec? Are there a tv-cards which can't capture to svcd or dvd?
I can't tell you, what tv-card I have because it's a no-name product but I know it has a Philips-WDM-Tuner.
Can anybody help me, please?
q-tip
I think more information about the rest of the machine would help.
To capture directly to SVCD or DVD format using a software encoder requires an incredible amount of CPU time. If you have less than a 1.5GHz Athlon or P4, the machine might not be able to handle it.
I have a 1.7GHz Athlon and I found I got much better results by capturing to AVI using Huffy codec and then converting to MPEG using TMPGEnc. The quality was noticably far better.--
Will -
Well, I have an AMD 1200 but I don't think this is the cause it doesn't work at all. If it would be working and the result would be of bad quality I would accept that the cpu is the cause.
My PC:
AMD 1200 Mhz
Windows XP
256 MB Ram
HD 25 GB free
TV-Card with Phillips WDM-Tuner
Geforce 4 MX 460 Graphics card
By the way: What program do you use to capture avi-Files?
PS: Almost forgotten: If I try to use Power VCR II to capture in SVCD or DVD quality the error message is:
"Unable to run capture graph" Does anybody know what this means? -
I still use AVI_IO, it is the only one that will not drop frames with my Winnov Videum 1000+Originally Posted by q-tip--
Will
Capture VHS, what formats to use
By Linuus in forum MacReplies: 6Last Post: 9th Apr 2012, 14:16 -
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 15:46 -
Philips Playback problems with widecreen formats
By ahhaa in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Oct 2009, 14:24 -
Audio problems with camcorder capture to dvd-r recorder
By illyad in forum Capturing and VCRReplies: 1Last Post: 9th Dec 2007, 08:53 -
DVD Formats
By Bluenote58 in forum MediaReplies: 9Last Post: 30th Sep 2007, 06:23
