Hi,
I have a Samsung CD-R/RW SW-212B and I'm trying to burn a CD-RW.
The burning itself goes fine, but when its 100 % and it's finalizing it says: Medium not present, but it just burned stuff on it !
Can somebody please tell me what this is and what I can do about it ?
Thanks in advance, Ralph
What application are you using to burn? Try a few different apps.
/Mats -
I'm using Nero, I tried it a couple of times (VCD) and it worked now, but now my DVD player won't read it.
So, how are you authoring? My DVD player (for one) refuses to play VCDs authored with Nero. Try VCDEasy (1.1.4) instead.
/Mats -
Just a suggestion have you tried different medium as in changing the brand....and update your firmware on your drive but be carefull with this to install correct up date as it can render your drive non working...
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
USB External Burner Problem- help?
By Super Warrior in forum ComputerReplies: 1Last Post: 3rd Jun 2009, 23:50 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 20:09 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58 -
Problem with HP DVD300e burner
By shinyranker in forum Authoring (DVD)Replies: 4Last Post: 22nd Jun 2007, 08:18
