  1. What codec's are there for .wmv files Links would be great
    Specifically i need the codec for this Movie.
    http://speedy.stileproject.com/video/wwf2.wmv
    i hope that helps u help me
    The movie is 4 min long
    Thx in advance
  2. Worked for me, had to install WMplayer7.1 to view the file but it played fine.
  3. That's M$ MPEG4 codec, d/load the newest media player and it comes with it.
  4. Thx i'd rather get just the codec cause i heard that the new version isnt as good as 6.? whateva version i got
  5. Aight i downloaded WMP 7.1 but it still wont work
    Can u give me a direct link to the codec
    not a website where i have to find it but A DIRECT LINK PLZ
    cause i cant find the codec
    Thx in Advance
