Hello
I have ripped and then used DVDShrink to make the movie to a nicer size. Now i want to create some menus for my movie, and all the guides a i look at shows how to load a .mpg file. Is there any application that alowes me to load the vob file so that i dont have to re-encode the movie for the movie already got the size i want it to have.
USiT
Well DVDlab ( Mediachance.com ) will accept VOBs, but I don't understand why you need to create new menus - if you use DVD Shrink correctly, this simply isn't necessary!
Arky ;o) -
Using DVDShrink to reauthor will not let you have any menus to navigate your disc. This situation might occur when you have discs where you really would like to keep some but not all extra material, and using "still pictures" is insufficient to yield an acceptable level of quality of your movie.
Then your only option is to reauthor the disc, and you will automatically loose all the menus.
/C
Creating Menus on avi files
By zammil in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2010, 14:27 -
Creating DVD menus with DVDAuthor(linux)
By sumit_pankaj in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2009, 12:00 -
Creating DVD Menus
By JARRE2000 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2009, 16:08 -
Creating menus
By Meriks in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2008, 16:11 -
need info on creating new menus on dvds
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 16:55
