authoring a mpg i get jerky playback on a pioneer stand alone player and the pciture seems to be on one side (the left) of the screen - what am i doing wrong??
playback on the pc seems to be 100%
What type of mpeg are you trying to make, VCD, SVCD, DVD or is the mpeg non-standard?Originally Posted by kcalczab
im trying to make a dvd from a mpg
i joint 2 mpg together
demux in tmpgenc then ifoedit to get the lot together
i dont understand why it plays ok on the pc but standalone is so bad
sound is out of sync as well?
please help
File : 1.50 Gb (1.75 Gb), duration 1:32:17, type MPG, 1 audio stream(s), quality 80 %
Video : 1.60 Gb, 2466 Kbps, 25.0 fps, res. 480*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 147 Mb, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported -
Several things come to mind here:
1st, for DVD, the audio needs to be resampled to 48khz., you can use TmpGenc with ssrc to do this.
2nd, joining VBR encoded mpeg files in TmpGenc can cause loss of audio sync, especially after the join point. Are you sure the joined mpeg is in sync?
You author in IfoEdit. Can you play the .VOB files from the HDD using something like PowerDVD. If so are they smooth and in sync? -
okOriginally Posted by bugster
1st - i didnt touch the audio so ill do that now
2nd - the mpg is fine and stays ok all the way through the mpg
and powerdvd plays the dvd fine from the .vobs in the folder
Jerky picture on DVD
By ANOther1676 in forum RestorationReplies: 1Last Post: 26th Feb 2011, 07:51 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky Picture and Sound on PS3
By det66 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th May 2009, 00:11 -
Jerky Picture and sound on PS3
By thumper66 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Mar 2009, 11:51 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26
