i have a film in ac3digital how can i get the sound to encode with the film
please help as im still a novice
It all depends on waht your target format is. (S)VCD requires you to provide mp2 audio, so one technique is required for that, DVD will support the Ac3 audio as is, as long as you use an authoring program that supports its import. Tell us what you are trying to do and maybe someone can help.
If your 5.1 is in a Divx or Xvid file, then you can extract it with virtualdub using direct stream copy, and then re encode it to a 5.1 Ac3 file with besweet with no probs, let me know if ya need more help.
Hercules Man -
I was wondering can you put AC-3 audio on VCDs (or XVCD or CVD)?
