Im trying to put the svcd to dvdr. i de multiplexed and multiplexed with 48khls or what ever special audio..i did it step by step. the video plays fine before you patch it. then when i go to preview play the file in ulead dvd factory 2 trial version the movie is cut off. the movie is playing the upper left corner of the movie.. i burned it anyways but the dvdr also plays the upper right. plz help. how do i patch it without make the pixels and everything mess up. what am i doing wrong?
I'm feeling generous tonight, youyr question is probably answered in the Guides at left, however here goes.
Your Title says DVDPatcher problems and then you say nothing about it in the text.....
BTB 48Khz audio is standard in DVDs.
Once you've got the audio set to 48Khz then you need to run DVDPatcher to set to 720 by 480 (NTSC) or 720 by 576 (PAL) and add to Ulead MF2
Author the DVD but do not burn it.
Then you need to use DVDPatcher on the authored DVD (*.VOB) files and patch back to SVCD then burn. If you skip the repatch to SVCD then gues what you'll see??
Yup a SVCD res video playing in one corner of a DVD res screen, exactly what you see.
Please let those of us that check the messages know how you made out.
Good Luck from "Been there done that" -
And almost forgot, once you've patched the header it won't play right if at all in Ulead MF2.
Cheers -
you said after you change the audio to 48khlz use dvdpatcher...are you saying after i multiplexed the new audio and video file together? or are you telling me to patch just the audio file. and how do you use the ulead dvd factory thing to change that file to vob dvd file? and at last how do i set the setting on the dvd patcher to patch the new dvd file back to svcd?
plz help your trick wont work because after i patch it to 720x480. the ulead factory 2 wont even let me use the file.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
anybody wanna help
