Hey,
I was wondering if anybody knew about or could recommend any dedicated MPEG-2 and/or MPEG-4 encoding cards for the PC (PCI preferably, but also FireWire). The Capture Cards section is just that, about capture cards... I just want a dedicated encoding card.
Thanks.
bestes
Flanders,
Meet me in Montana.
xoxo
Jesus H. Christ -
comp usa has one for $650.oo
i think its called realmagic
quartet has a real nice one
but you have too use your mouth to get that one as they only sell to businesses
i talk my way into one before
but i sold it when instantcopy 7 came out
realmagic
http://www.compusa.com/products/product_info.asp?product_code=50121925&pfp=BROWSE -
Looking for a hardware card that only assists in encoding?
The old MPEG SuperCharger from Discreet worked in conjunction with Cleaner 5, but that kind of hardware has bitten the bullet.
If you are asking for a card that just encodes, realize that those are expensive and prioprietary for use with the encoding software.
These encode to MPEG2 with hardware (during capture):
MATROX RTX100
http://www.matrox.com/video/products/rtx100xtreme/home.cfm
Excellent professional card.
CANOPUS MPEG PRO EMR
http://www.canopus.com/US/products/MPEGPRO_EMR/pt_MPEGPRO_EMR.asp
This one looks new. I don't remember seeing it before! Finally a lower-priced quality Canopus item. External USB 1.1/2.0 device.
CANOPUS MPEG PRO MVR
http://www.canopus.com/US/products/MPEGPRO_MVR/pt_MPEGPRO_MVR.asp
Internal PCI version. Same price. Same item.
CANOPUS AMBER
http://www.canopus.com/US/products/Amber/pm_amber.asp
DV input with MPEG output. Older card. The newer MPEG PRO series looks more promising.
HAUPPAUGE WINTV PVR
http://www.hauppauge.com/html/wintvpvr_datasheet.htm
A mediocre card with horrid software. Only good point is that it is cheap. Not enough encoding options as compared to an ATI or the ones above.
ATI ALL IN WONDER 9800
http://mirror.ati.com/products/radeon9800/aiw9800pro/specs.html
Though all previous All In Wonder Radeon cards used a hybrid form of hardware-assisted MPEG encoding (based on Ligos GoMotion technology), the newest AIW Radeon features a chipset that does a majority of the MPEG encoding natively in the hardware, releasing even more of the CPU load.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Can't you just check (mpeg-2 / mpeg-4) in the capture card list to get ones with those features ?
If you are going to spend $, why not buy a replayTV or something. I believe you can network them and pull the mpeg right off. -
i think he just wants a mpeg adapter card (it has nothing to do with capturing as u run your video out into it , but it encodes video at blazing speed)
but the are expensive $600.00 plus
and some of them are not so good with multi angled dvd (about 75% of all dvds) as they will have A/V sync problem
but with non multi angled dvds (usually episodes discs and older movies) and other video projects they work great -
Hi bestes,
I have the Realmagic DVR board for about 3 years and I never had it work correctly. It has been back to the factory 4 times, for replacement, modfiication, and everytime I get it back same thing. Intermittent blue screens, intermittent lockups, dvd playback problems. So I bought a Canopus DVStorm 2. I put it in the same system, loaded the software, and never had a moment of grief. The Realmagic card is still at the company (for over 1 month), still no problems found, and they won't buy it back.
Spend the extra money and go with a Canopus card!!
http://www.canopus.com/US/products/MPEGPRO_MVR/pm_MPEGPRO_MVR.asp
Steve
Dedicated Video conversion PC
By tonyaldr in forum Video ConversionReplies: 14Last Post: 14th Aug 2011, 23:08 -
Is it time for a new forum dedicated to 3d video?
By yoda313 in forum FeedbackReplies: 18Last Post: 10th Apr 2011, 10:51 -
Looking to Build a Dedicated Encoding System
By Scarpad in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 13:10 -
Capturing screen image to video - using dedicated card - what software ?
By ullteppe in forum Video Streaming DownloadingReplies: 10Last Post: 12th Oct 2008, 10:34 -
getting new PC: use onboard video or PCI-e dedicated video card?
By alandla in forum Newbie / General discussionsReplies: 18Last Post: 27th Feb 2008, 10:13
