Results 1 to 10 of 10
    Nov 2001
    West Virginia, USA
    I have an Oritron 720 dvd player and got the hack to enable vcd working. I tried a vcd i burnt using NERO (Wizard) it didn't work. I know there are different ways to burn a vcd. different settings. i have read about using unauthored mpeg iso's. any help will be great. Thanks.
    Bob
    Apr 2002
    The State of Frustration
    To enable VCDs, or CD-Rs? It appears according to the database, the jury is still out on whether your player plays CD-Rs ((S)VCDs). You may want to consider replacing it with a more universal player.
    Hello.
  3. Try VCDEasy. You can d/load it either to the left under tools or from http://www.doom9.org
  4. I experienced that VCD's burned with Nero (Express) show up in Explorer as being only a few kilobytes total size, and the DAT file is unreadable from the PC. However, it will still work just fine in my Pioneer DV-444. Burning with VCDEasy instead of Nero removed the problem for me, maybe its worth a try for you too. VCDEasy will give you these different settings you mentioned.
    Nov 2001
    West Virginia, USA
    downloading and tyring now. will respond how it goes
    Nov 2001
    West Virginia, USA
    i dont thinki tried the right settings. i tried to burn a vcd and i got an error with an alarm and this is what was on the screen:
    [Internal Xml Generation]
    Internally computed XML generated successfully: "D:\Documents and Settings\Administrator\My Documents\videocd.xml"
    [00s 040ms (Internal Xml Generation)]
    [VCDxBuild.exe]
    GNU VCDImager 0.7.12
    initializing libvcd 0.7.12 [cygwin/i686]
    changed volume number to 1
    changed volume count to 1
    changed restriction number to 0
    changing 'next volume use sequence 2' to 0
    changing 'next volume use lid 2' to 0
    changed volume label to `VIDEOCD'
    changed publisher id to `VCDEASY_V116'
    changed application id to `CDI/CDI_VCD.APP;1'
    changing 'relaxed aps' to 0
    sequence count 1
    adding sequence #0, D:\Documents and Settings\Administrator\Desktop\`Recorded TV Shows\Cheers 5 min Clip.mpg
    pts start offset 0.282500 (max pts = 301.604956)
    playing time 301.322456
    scanning mpeg sequence item #0 for scanpoints...
    already scanned... not rescanning
    pbc: psd size 0 (extended psd 0)
    iso9660: highest alloced sector is 224 (using 300 as isosize)
    writing track 1 (ISO9660)...
    writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
    MPEG packet statistics: 18601 video, 3704 audio, 0 zero, 0 ogt, 311 unknown
    writting post-gap ('leadout pregap')...
    finished ok, image created with 23291 sectors [05:10.41]
    [09s 694ms (VCDxBuild.exe)]
    [CDRDAO Disk Info]
    Cdrdao version 1.1.7
    ASPI: D:\Program Files\ahead\Nero\WnAspi32.dll
    1,0,0: ATAPI CD-R/RW 24X10 Rev: P.JJ
    ERROR: No driver found for 'ATAPI CD-R/RW 24X10' (Use "Force Driver" in the "CD Writer/Reader" settings page to set a driver manually)
    ERROR: Cannot setup device 1,0,0.
    [01s 512ms (CDRDAO Disk Info)]
    [11s 586ms (All tasks, and user interactions if any)]
    It says no driver for cdr/rw drive. Use Force Driver. I have never needed a driver ( windows recognizes it and doesn't ask for one ) also the Force Driver option, didn't find it anywhere. I went to acer's web site ( the brand of cd drive) and i didnt find drivers for my drive. any ideas?
    Bob
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Now, this is a CDRDAO error message. You probably haven't got your ASPI layer set up correctly. Try the ForceASPI installation (Tools/Burn). If that still wont help, go to the CDRDAO home page and take a look at the compatibility chart to se what driver (if any) to use with your burner.
    Last resort (and not a bad one at that!) is to just create the VCD image with VCDEasy (uncheck the "Burn" checkbox on the main page) and then use Nero to burn the cue/bin (File -> Burn image). Also, keep the burn speed low. This has been argued, but on some systems it actually seems to make a difference. I use 4X when burning (S)VCD.
    /Mats
    Nov 2001
    West Virginia, USA
    the box at the bottom where it says Tools is greyed out.and it just says ASPI Tools support is disabled. also i went to CDRDAO homepage and there were no listings for my Acer 24/10/40 cd-rw drive
    Nov 2001
    West Virginia, USA
    i have tried 1.1.6 and 1.1.5.2 and the option for ASPI is greyed out on both versions? any idea where i can find the right driver?
    Nov 2001
    West Virginia, USA
    i have downloaded updated ASPI drivers and tried everything i can think of. I think i ma need the drivers for my cd-rw drive but cant find them. I found some but they were listed as being for Win98. I am using Windows2000. The driver is an ACER 2410A.
