I wanted to convert a 2 part NTSC (23.976) Divx file with AC3 audio to PAL DVD-R, while preserving the AC3 audio. I joined the files in Vdub, changed the frame rate to 25 fps, and saved the Video only. I converted the video with CCE 2.5, no problems. I extracted the AC3 audio with Vdub and ran it through Besliced to check for errors, errors were found, but fixed. I used Besweet to change the AC3 audio rate to the equivelent of 25fps, which seemed to work. The files authored ok, and the DVD played fine, and in perfect sync on my PC, but not on my standalone. I have narrowed the problem down to Besweet, it is somehow making the AC3 audio unrecognisable by my standalone during the conversion. Has anyone had any succes converting AC3 from NTSC to PAL, is there any other program that will do the conversion or am i just using Besweet wrong?![]()
I have converted many, 2 and 5.1 channel wav files to Ac3 with Besweet, not had a problem yet, top program.
Hercules MAn
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
