Hello, when I resize an XviD video from 576 x 240 to 720 x 300 (for DVDR) in TMPGEnc it seems to be using a nearest neighbor method rather than interpolating the result.
Any ideas on how to achieve a better result?
720 x 300 ? this is not a valid DVD resolution. If you want to create a DVD compliant mpeg2 file use one of the templates.
I was suspecting something like that, I am using "Full Screen (keep aspect ratio)" in TMPGEnc so maybe it is blacking out to pad it. I am just about to author it so it may complain. If that is the case I may have to crop it down to 16:9.
Somewhere I heard not to use TMPG to resize. Something about the resize method. May want to use virtualdub precise bicubic.Originally Posted by RzSwede
Originally Posted by RzSwedeI was just wondering, are you going to try Mr. Tucker's idea or not?Originally Posted by Craig TuckerHello.
Just use a template it will automatically resize it to DVD resolution, if you use full screen keep aspect ratio it will encode black bars top and bottom to maintain the aspect ratio of the original divx.
I am using the template however I would like to try using virtualdub instead as I am not convinced that TMPGEnc's resizing appropriate. Virtualdub appears to have the bicubic options, however I can't get it to output to mpeg2 (even with Virtualdub-Mpeg2).
Still playing around with this. Thanks for your suggestions so far!
How to resize an online video
By Maylon_Brando in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2012, 05:58 -
TMPGEnc resize problem
By Vatrik in forum Video ConversionReplies: 17Last Post: 15th Mar 2010, 06:27 -
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 13:49 -
Tmpgenc Xpress 4: I Don't Want To Resize
By Tom Saurus in forum Video ConversionReplies: 17Last Post: 16th Nov 2009, 14:18 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 19:06
