Im having a problem making an svcd which will display properly.
I have an mpeg2 file which i downloaded off the net which i want to burn as an svcd. The mpeg file is flagged as 16:9 generic.
If i play the file directly in windvd it plays fine with large black bars at the top and bottom.
If i put this on an svcd using vcdeasy and load the image using daemon tools then when i play it in windvd then i still get black bars but they are about half the size which makes the video look stretched.
Is there any way to make it play properly without re-encoding (the videos not great anyway, i dont want to re-encode)
did you try the cd on a dvd player/tv?
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
.er... excuse me for asking, but if you don't have a DVD player, why make a SVCD at all??
/Mats -
im archiving a lot of the video off my pc onto cds. Better to burn them as vcd/svcd then to put the mpegs oto a blank and have to rencode the lot again when i get round to buying a dvd player.
Anyone got any suggestions to my problem? -
DVD players don't support 16:9 playback from SVCD. The only way would be to re-encode with the black bars inserted. SVCD does not support 16:9 pulldown flags.
My Hi-8mm video camera has 16:9 Full and I got that to play as a SVCD correctly on a wide screen tv. TMPGEnc was used to encode the MPEG-2 file from a 720 x 480 capture of the (normally 640 x 480) video. Nero burned the SVCD, however, TMPGEnc was used in the DVD mode and not the SVCD mode. Compliance was unchecked in Nero. There were two advanced options in TMPGEnc that worked. Most did not. Use 16:9 display and use Full Screen (Keep Aspect Ratio) or Full Screen (Keep Aspect Ratio 2). Both worked.
Sony Vegas Widescreen Problem
By Quackulator in forum EditingReplies: 3Last Post: 20th Apr 2010, 19:12 -
Mp4 / H.264 / widescreen problem
By mrjoetoff in forum Newbie / General discussionsReplies: 13Last Post: 23rd Aug 2009, 10:05 -
Widescreen Problem When Capturing
By DW in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2009, 05:46 -
widescreen dvd problem
By seanin in forum MacReplies: 2Last Post: 6th Jan 2009, 18:25 -
Vegas render to 16:9 widescreen problem
By EMPERORelement in forum EditingReplies: 10Last Post: 19th May 2007, 16:32
