i have got some films that play perfect on win media but when i go to encode with tmpge plus i get no sound but gspot says that i have 2 compatible codecs what am i doing wrong please help as im a newbie
You are not giving enough info on what you are doing, thats why no ones posted any replies, if your going from Divx or Xvid with Tmpgenc, then you should not have any probs, what files are you converting from ect, please explain more.
Hercules Man -
yea more info would be help full but i think i got a idea for you i had a simular problem when i first stated i was trying convect xvid to svcd and my sound and video cut out after about 5 minutes it now i dont have tmpgen on my puter right now ( i had a crash) so i cant be sure that my information is acurate but what i did was i changed the direct show mediia i believe is waht is is called i moved it pirority from -1 to 1 and it worked great
You don't give enough information. We need a little bit more info (audio codec, etc) in order to be able to give an answer. Still, we can gues what happens, so...
I had a similar problem. I encoded (or transcoded) the audio to AC3 format from a wav file that worked fine, and the MPEG2 file did not have any sound. I used BeSweet, and I played a little bit with the values I could change. Finaly, I found the problem. The AC3 file has to be coded at a specific bitrate to be DVD compatible: 384k.
It might be possible that this is your problem to. -
i have a simalar problem, i ripped a movie from dvd, the mpegs and the bin/cue files did not have any audio. i used easy vcd to rip it and vcd easy to burn it. so far it is just this one dvd, none of my others have had this problem.
the film is avi when i try to extract the audio using goldwave the audio comes up as osloskop file i try to encode it using tmpge on mpeg1 but the sound is still not there the film says that its an avi but a part comes up as viteosloskop
Hey guys,
I have a similar problem to the one the original poster's facing.
I've got a .mpg file which I assume is in SVCD format because the screen size is 480X480. When played in Windows Media 9, media player searches for a new codec, downloads it, then says there's an error d/l the codec. This process happens even after I restart media player. The video plays, but the audio seems to be in slow-mo, and I can't fast-forward the clip.
I tried to re-encode it in TMPGEnc and the video came out fine, I could fast-forward but there's no sound!
Am I missing an audio codec? Ive got Nimo, DivX already installed.
Media Player tells me the video codec is Cyberlink Video/SP, but it doesn't know what the audio codec is. Is there any way of finding out?
thanks!
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 08:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
