How do I make all these formats readable by my dvd player... Of course the quality of some of these are not very good but I don't really care. I collect some of these humorous clip and I like to put them on a CDR but I like to be able to show them on my player instead of using my computer. Thanks.
https://www.videohelp.com/convert
Check out the guides there. They will be able to answer most of your questions. You will be looking to convert your files into a VCD compatible file type.
Also before you do that check your DVD players manual to make sure it can play VCD (Video CD) and/or SVCD (Super Video CD).
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 04:53 -
Algorithm convert DAT to AVI
By Nemo_wf in forum Video ConversionReplies: 5Last Post: 5th May 2010, 04:18 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19 -
Converting .dat to avi
By demonwarrior in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2007, 03:18
