Ok, I've been looking around now for sometime and see that each DVD that is written / burned has a 'Book Type' or 'Disc Category' that states DVD-ROM, DVD-R, DVD+R, etc.
I also see that some standalones need DVD+R(W) to be identified as DVD-ROM for them to be played properly and that some DVD burners can be fooled by using Bit Setting programs while others cannot (specifically SONY and NEC multi-format ones). Similarly NERO includes these settings, but again some burners don't recognise them.
My question / point is this:
DVD burning software allows you to specify whether you are burning DVD-ROM, DVD-Video, etc. Therefore, surely it follows that the 'Book Type' must be stored somewhere in the image that is burned to the disc. If so it must be possible to change this either in the burner OR in a disc image (e.g. produced by Imgtools or similar).
Does anyone know how to do this? Does DVDDecrypter or Imgtools, etc. allow this. What about 'backed up' DVDs, when is the disc type determined - on burning?
Any help would be most grateful as a friend of mine is having problems reading DVD+R discs on his standalone.
J
Results 1 to 1 of 1
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
