i've searched google, and the vcdhelp archives and such, and cant find anything on this:
"index of scan line is out of range(384)"
ok, info: .avi in Xvid codec, trying to encode to any format (vcd, svcd, and tried the kvcd template). it only happens when i try to change the source range. any ideas? any help is much appreciated!
later
whats in a sig?
Have you scanned the file for bad frames with vdub.
I have had numerous problem when I recieve files from friends with the Xvid codec.Originally Posted by Aemon_
My solution is to run the file through VirtualDub and save it with the Huffy codec, no quality is lost. Then TMPGEnc can handle it with no problems.--
Will -
well, i tried to change it to the huffy codec like you suggested, but it wasnt there, so i used divx instead. it worked! thanks for your help!
laterwhats in a sig? -
Be aware that when you recompress a file (xvid>divx) that there is always a loss in quality.
That's why huffy codec was suggested, it's close to lossless compression, unlike divx.
"Art is making something out of nothing and selling it." - Frank Zappa -
so i just download the huffy codec and vdub will be able to use it?
thanks!
just to let y'all know, i got the codec and recompressed the avi. worked great, and encoded fine. thanks alot!
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 20:30 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
