Ok, currently the only FOOLPROOF method I know of to do this is:
1. Rip the SVCD's to MPG.
2. Join up the MPG files in TMPGEnc's MPEG tools section.
3. Run TMPGEnc with the NTSC DVD template, slightly modified so that it'll be sure to make it FIT on a DVD-5.
4. Wait approximately double the length of the movie.
Now, I've been fiddling with Main Concept MPEG Encoder, but the output seems of substantially lesser quality in this case. There aren't many options at all in MCE, or am I missing something?
And... is there ANOTHER method that I'm not thinking of? Please don't say to use CCE, as I find the idea of writing scripts and then having them not work about 100 times until I discover CCE Zen to be horrifying at best. I'd rather have a root canal than use CCE in its current form.
- Gurm
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
