I having been searhcing to try and find the answer to this question for some time now. Obviously there probably isn't such a clear cut answer, but some people out there must have a gut feel with some reasons for them. In particular the DV Codecs I have encountered include
* Adaptec DV Codec
* MainConcept DV Codec
* Panasonic DV Codec
* Canopus DV Dodec
* Sony DV Codec
I am sure there are loads more as well. I am using the codecs for offline movie creation in Windows (with VirtualDub), so speed of compression is not a particular worry. I am more interested in quality. So if anyone could let me know which ones they recon are particularly good, or terrible for that matter it would be greatly appreciated.
Thanks in advance
Since DV is hardly compressed at all, how much difference can there be? (Across the major ones) How would you compare them? Color Bars? Resolution Charts?
I'm interested.
Have you noticed any difference ? Are we talking decompression only? I mean, you dvcam does the compression using it's own, right? -
I'm kinda partial to the Canopus myself.
The codecs are USUALLY used just for decompression, but if you do any FX/titles/transitions/compositing in your editing of the stuff, the codec gets used for recompression during the rendering, so YES it does make some difference.
Just like with MPEG2, the stuff that taxes the codec is the fine detail, random moving, jumpcut (well that's more for just MPEG), and hard edged kind of stuff. This will include fancy titles, water splashes, swish pans, fluttering foliage, jumbles of people and, oh yeah, also recognizable moving smooth color gradients. These are great examples to try to test variations on. However, color bars & chip charts are also often used.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Re-Codec
By Casper_H in forum AudioReplies: 1Last Post: 21st Feb 2008, 08:10 -
which codec
By peterg60 in forum Video ConversionReplies: 6Last Post: 25th Jul 2007, 15:52
