Hi,
im thinking of buying a standalone dvd recorder, preferably one that writes DVD-R/W, DVD+R/W, multiregion, and reads all formats, id also like av in and out, now the one i have found is the SONY RDR-GX7 althouhg pricey i think i may be able to get a good price, does anybody have any experience with this recorder?
Also are there any other dvd recorders which meet all or some of the above sort of specs, thanks in advance for any comments.
kas187
My peeve is that the unit has no hard drive for the price they want for it ($1,300CAD). Way too pricey for a non HD standalone...
well since im in the uk and have been shopping on the net and the cheapest price i found yet was £595.00 at
http://www.multimod.com/uk/shop/50-sony-rdr-gx7-multi-region-dvd-recorder.html
but im still searching for a good deal, thanks for the info
kas187 -
I agree. This thing is too expensive, especially when you consider that the +RW portion of this recorder is greatly sacrificed. And keep in mind that this recorder does not work with DVD+R, only DVD-R, DVD-RW, and DVD+RW
Read this article before you buy this machine:
http://www.dvdplusrw.org/video/sony_dualrw.html -
hi piano632
thanks for your input and reading that article makes me think again about buying the recorder. I guess i best think again in what i want, thanks again and much appreciated for your input to all who replied.
kas187 -
Yes, I should have mentioned that the article is obviously biased towards the + format since it is a DVD+RW site.
I would definitely have to agree about the Philips machines. There are countless complaints about them all over the internet. If you want a reliable +RW recorder, I think the Yamaha DRX-1 is good (and the irony is that it's made with Philips parts). Only problem with the Yamaha is it doesn't record in 2-hour mode, only 1 hour then jumps to 2.5 hours.
I imagine the Magnavox units would be the same as Philips, but haven't heard anything about them.
I guess we'll have to wait and read the reviews on the RDR-GX7 to see if it's worth it.
Where is Pioneer when we need them?
SONY RDR-GX7 FIRMWARE available for GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 14Last Post: 26th Dec 2009, 15:24 -
Sony RDR-GX7
By joecass in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2009, 18:53 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR GX7
By Macdon22shippTWO in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Sep 2007, 11:55 -
RECOVER DVD - Power Failure Sony GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th May 2007, 11:13
