I have some very old tape's I wanted to back up and I have a ATI Radeon 32meg and a Dazzle 2. I found that old tape's with the Dazzle 2 have alot more sound pop making the audio out of sync. The ATI AIW use's a Line-in cable. Where the Dazzle take's the sound into the mother board then send's it to the sound card. There is still a problem with ATI AIW with old tape's I live in the USA and every thing I have is NTSC but I do have a world wide VCR made by Samsung. For some reason bad tape's the ATI AIW will bend the picture to the left. so the picture is very bad. The fix I used was tell my samsung vcr to send the picture out as PAL-N and tell the ATI AIW to capture in PAL-N this fix the picture problem. you could still see a little problem with the picture on the PC but on the TV it was cropped off. Also the Dazzle 2 VCD setting there some thing they took out of the MPEG 1 streem that some DVD player's will not play VCD's. I just made some VCD's with my dazzle 2 on my Sony DVD player the VCD's do not work only on my APEX but when capture with ATI AIW they play on the SONY. I would say if your capturing from satellite get Dazzle 2. If you need to back up old tape's ATI AIW but you might run in to a picture problem and will need a world wide VCR to fix it. I going to get a Hauppauge WinTV PVR-350 card and see how that is might be better the the Dazzle 2 and ATI AIW. But what you capture different card's are better at different job's
I experimented with the Dazzle DVC last year for making some VCD's from handycam. I found that its VCD encoding quality was poor when I rendered in Moviestar 5. But they did play in my DVD player(s).
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 16:58 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Is my ATI TV Wonder 650 damaged, or did I just pick a bad test tape?
By Mini-Me in forum Capturing and VCRReplies: 17Last Post: 7th Dec 2010, 00:54 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Timebase error test tape
By danno78 in forum RestorationReplies: 2Last Post: 28th Feb 2008, 06:13
