I converted an Xvid file to a VCD and burnt it. So the video is fine, and there is audio, but it is about 5~7 seconds behind the video.
I just got ffmpegX so I am a noob at this
but I would appreciate any help with this.
Oh, and it is not the Xvid file, I checked it and its audio is fine.
AnonymousGuest
AnonymousGuest
Thanks Rasta, I'll check that
AnonymousGuest
Rasta I have one more question for you (well for anyone who can help)
You said to keep the framerate and the sampling the same, but the options given to me dont match up. Atleast not that I can tell.
here is what FFMPEGX gives me as options:
framerate :
NTSC Film (23.976)
NTSC(29.97)
PAL(25)
Unspecefied
Sampling :
48000Hz
44100
32000
22050
24000
11025
12000
or am I looking in the wrong place.....
thanks for any help again
You are looking in the right place. But what is the framerate of your source file? And what is the sampling rate? You can find this out by clicking on Info in the upper right corner. If you click that you will see what the framerate is: for example 29.97 fps and what the sampling rate is: for example 414000 Hz. Now you must check the corresponding options for the output file.
" Military intelligence is a contradiction in term."
- Groucho Marx
AnonymousGuest
Much thanks again Rastapiggy,
now I have encountered another problem, when I load the file and try to click [info] it doesnt do anything
it just sits there and does nothing. I waited about 3~4 minutes incase the process takes sometime, but still nothing. Am I doing something wrong? Or is it something else....
Thanks again in advance, and sorry to keep bugging you
AnonymousGuest
Nevermind I restarted my comp and it suddenly started working.... go figure...
but oh well, thanks for the help rasta
audio not in synch
By ak.premkumar in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2010, 10:51 -
Out of synch audio
By Maxwellbest in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 10:33 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
audio synch
By Usagi in forum DVD RippingReplies: 5Last Post: 28th Dec 2007, 19:11 -
Audio goes out of synch
By Semaphoric in forum Authoring (DVD)Replies: 3Last Post: 27th Sep 2007, 22:01
