Hi
I'm just taking a look at your templates.
What is the enhanced video CD one all about??
Is it standard compliant VCD??
If so what is different from the standard template??
Cheers
Fozzee
Hi There,
The "Enhanced VCD" Templates are like "regular" VCD but with a few minor modifications, and the biggest one is the 48khz in the Audio, which rather makes them "non-standard" but ready to be burned on DVD-R media instead of just CDR/
Personaly, i'm using them myself instead of the VCD Templates and i've had no problems on any DVD Player, although a VCD Player will have problem in the Audio, but if you plan on getting a DVD Recorder, it will be easier to do a "migration" of those movies since they will already have 48khz Audio.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 09:01
