I've just authored and burned a dozen or so DVDs, only to discover that the files in the VIDEO_TS folder are not all in capitals:
The folders are in capitals and it plays OK on my DVD player, but are other set-top players more 'picky' about capitalisation?
Regards,
Rob -
I think 'in theory' they have to be in caps but it prob dont matter, same as 'in theory' you gotta have an empty AUDIO_TS folder too.
I dunno if you're familiar with IFO edit
This program does just that (while it fixes your region coding if you like)
OPEN any file in the VIDEO TS that's not captitalized and it'll offer to change it for you right away..and if its an ifo, it'll suggest carrying out such capitaliztion changes to the .bup's that correspond as well -
I know some people have had issues on stand alones with the VIDEO_TS AND AUDIO_TS folder names nor being in all caps. If you can make the file names in all caps, what's it gonna hurt?
PAL or NTSC camera : does it matter ?
By kirby7777 in forum Authoring (Blu-ray)Replies: 9Last Post: 14th Aug 2011, 15:51 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 11:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 23:59 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 23:38 -
Does it matter what you use to capture DV tapes to computer?
By deacea in forum Capturing and VCRReplies: 2Last Post: 19th Nov 2007, 00:20
