When I try to compile a project it aborts and give a "serious" error message. Problem is it doesn't say what the error is or what file is a problem.
I checked all my files and they are ok. They have all the same bit rate, frame size and audio encoding.
How do I find out what's wrong?
MPG2 files were encoded with Video Studio 7 from avi capture.
Have not run across that error before.
Maybe you should post this in the DVD-Lab forum over at http://www.mmbforums.com/
There are a lot of knowledgable DVD-Lab user there.--
Will -
I am having that same problem now because DVD-Lab doesn't like one of my video files & I don't know what it's problem is and no one in that forum seems to have a straight answer. Does anybody here know what the problem is?
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
[DVD Lab] can not function in the "Compile DVD ..."
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 27th Aug 2011, 11:07 -
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 21:46 -
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 21:45 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
