I just returned my RCA DRC212N Progressive Scan DVD Player because, (although it worked) some of the menu fetures were annyoing, it had no display on the front, and felt very cheap!! It played every DVD-R I made that played on my PC....
SO I exchanged it for a Panasonic F65 because it had more features (I also hated the RCA remote) a decent remote, 5 disc changer, etc....
Well this DVD player wouldn't play a single DVD I had burnt and used with the RCA. Using TMPG, Nero, DVD2ONE, DVDSHRINK etc..... Really annoying, my friend and I both bought the RCA, felt the same, and both bought then Panasonic. I've tested both of them and don't know what's up.
Anyway just thought I'd pass the ingo along..... and some links
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&dept=11&WLBS=fsweb11&...=&newdeptid=11
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&dept=11&WLBS=fs%2Dweb...=&newdeptid=11
After looking at the link for the Panasonic, they talk pretty highly of it, maybe I'm doing soemthing wrong........
If you can live without the 5 disc changer, the Panasonic S35 does it all. It plays everything I throw at it, burned from several different programs. IE: DVD Shrink, Nero, MY DVD, IC7, etc. Costs less than $90. and its progressive scan.
Burn Baby Burn
It's a Disk-o Inferno -
I'm thinking of getting either the Panasonic S35 or the Panasonic F65. Other than the 5 disc support are they very different from one another? Do both support a wide range of media? I've heard good things about the S35 but like the idea of having 5 movies to choose from. If the F65 is just a S35 with a 5 disc changer i'll probably buy it.
TIA
sydemon
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 19:57 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 02:58 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
