I've a very simple question.
Previously I can watch VCDs 2.0 with Windows Media Player 6.4 in Win 95, but now after upgraded my PC, I can't watch VCDs 2.0 with Windows Media Player 7.1 in Win2000. The error message is
"...DirectShow Codec .... may be not installed"
The file that Windows Player 7.1 has problem opening is "AVSEQnn.DAT"
BTW, I don't have problem with VCD 1.1 in Win2000.
Have I forgotten to install something?
Pls enlighten me.
Results 1 to 9 of 9
Hmm? Did you try to open the file from within WMP? I know that winXP doesn't like that. Instead you have to run explorer, right click on the file and choose 'open with'. Not sure if this holds true in win2k, but it might be worth a try.
You might want to try to d/load wmp9 -
WMP is no (S)VCD player. Use a software DVD player (PowerDVD, WinDVD) to play (S)VCD on a computer. If you're primarily going to watch your videos on the computer, just keep your movies as mpegs (no need to author as (S)VCD).
/Mats -
Originally Posted by mats.hogberg
I've tried various software such as XingDVD, PowerDVD even Windows Media 6.4 but all of them can't open VCDs 2.0 in Win 2000. But I don't have this problem in Win 95, suspect there is some "DLL" files missing in Win 2000. BTW my Win 2000 is upgraded to SP3, so what else have I forgotten to install?
My PC is Pentium MMX, but Win Media 9.0 requires Pentium II. -
Install adaptec's aspi. Some time it helps, for a strange reason!
Also, install a mpeg 2 software program, and then unistall it but leave the mpeg 2 codec in your PC. This way it might play with windows media player.
A good player for older PCs, is STHSVCD (or STHDVD) you can download here: https://www.videohelp.com/tools.htm#players
I succeed to watch a SVCD at a pentium 90mhz with this proggy! -
Originally Posted by SatStorm
Maybe this is your problem:
Windows 2000 may not be able to access the files on a video CD. This problem occurs if the video CD is authored with third-party software, and if the Joliet (Secondary Volume Descriptor and directories using Unicode) option is selected. When this problem occurs, Microsoft Windows Media Player may also generate an error message that indicates that the format is not supported.
This bug was fixed in the newly released Service Pack 4 for Windows 2000. -
This is the same reason why when you rip direct an SVCD to a HD, without using programs like "Iso Buster", on w2k, you get (sometimes) broken files. Rip the same discs on win 98SE and there are no problems.
Excellent, that makes faster the SVCD ripping proccess also for w2k I think. -
Originally Posted by baseband
Bingo, SP4 solved the VCD 2.0 problem. I can now watch VCD 2.0 in WMP7, XingDVD etc......Thanks a bunch!!!
watch TV on my PC?
By wcwman18 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2011, 03:35 -
Watch 1080p
By anirban in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2008, 11:17 -
How to watch a movie?
By shapper in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2008, 20:59 -
Are you a watch wearer?
By yoda313 in forum PollsReplies: 33Last Post: 1st Jun 2008, 20:09
