k..... i've looked around and i can't really find any info on this...
my dad just came back from europe and he haas a sotore bought vcd.... but the damn thing is in PAL... whats the best way to convert it to NTSC without loosing and quality?????
thanks
The first thing I would suggest is just sticking it in your player and trying to play it. A lot of US players can play PAL just fine. The problem is that not all of them can output an NTSC signal for your TV from a PAL source, so it still may not work.
You can't convert it without losing any quality because you'll have to reencode. How much of a loss you'll take depends on the material, it may still be acceptable to you. It's a pretty straightforward frame rate conversion, from 25fps to 23.976fps. There's a general guide for it:
https://www.videohelp.com/forum/userguides/78178.php
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 22:40 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
