I have just made my first video and when I play the DVD on my PC the quality is great. I have a 17" LCD display. I then take they DVD to a dvd player hooked to a TV and the slide show is fine but the video clips are not nearly has nice as when played on my PC. The video is sports action shots and they players running look like they have another player just behind them a frame or so. almost like the option in windows to have a trailer behind your mouse pointer.
Is there a setting that I need to change during the conversion?
Jim
My first inclination is that the fields are out of order. I'm guessing that you probably captured in AVI, then converted the AVI to an MPEG-2. During this conversion process the field order is incorrect and the image has what is known as jitter.
If this sounds right, swap the field order in your MPEG converter. My system always seems to go toward Top First(A). -
And don't let your converter detect the field order - I've found that TMPGEnc doesn't always use the correct field order. Keep in mind when setting your field order: captured analog video; top (A) field first. Digital video; bottom (B) field first.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:09 -
DV playback !
By achakzai in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th May 2008, 03:04 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
playback on tv
By andyluong99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 17:08
