i have read through the forums quite a bit and there is varyed information on my question, which is, When converting to MEG2 to burn to DVD from Div-x will there ALWAYS be a audio delay problem...?
If so..... do i run the audio AND video through Virtualdub stripping it way from each other and saving as seperate files? or just take the audio?
Thus putting them back together as one complete happy shiny well behaved DVD?
This may well be answered in the "HOW TO" section of the site, but i could see anything......
So any info on these questions would be much appreciated.....
D
Never buy a dumb midget, its not big and its not cleaver!
No, converting a divx does not always result in an audio delay. Usually that indicates that something is wrong, like bad frames.
You should strip out a wav file and use that as the audio source, no need to bother with the video at all. I prefer Goldwave for wav extraction as Virtual dub has problems with VBR-MP3 audio and cannot convert AC3 audio. Check the Guides section on how to use Goldwave.
If everything goes as planned then TMPGEnc should create a shiny, happy mpeg for you to author to DVD.
8)"Art is making something out of nothing and selling it." - Frank Zappa -
Right thats cool, i have goldwave already, although i have tryed to use it, when i converted the audio i just got a large offensive hissing sound? even with the AC3 codec installed?
As for Authorising the DVD, i know there is plenty of good programes out there and you have to find the one best suited to yourself, but what are the most reliable and easiest to use?
Many thanks......
D
Never buy a dumb midget, its not big and its not cleaver!!
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26
