Results 1 to 11 of 11
  1. hey ive just followed a guide which goes through the required steps which i should follow ! i have done this and let it encode which took about 1hr. I then went to see the finished product and there was a few problems? 1 was the picture was jumpy and kept having a sort of spazim, 2 the audio was totally out of sync. any1 know why this has happened?
  2. Can I assume you checked the avi (?) file you converted? To see if it was beat up?
  3. yes u can assume that. i had them in 2 seperate mpeg files, they were both fine. i mergeed them together etc and it turned out all weird
  4. If the original mpg files weren't created by TMPG that may be the problem. For some reason TMPG supposedly has problems with the merge/cut function with mpgs it didn't create. Try making DVD compliant files out of each part separately and then merging them with TMPG.
  5. ook thnx for the tip, can u tell me how to go bout making dvd complaint ones? also laddydaddy did u read my post in reply to urs on my post called Guide?
  6. If your film source is an svcd then you have two or three discs each with an aveseq.mpg file. When you open TMPG close out the wizard. For the video source choose your aveseq.mpg from the first cd. It will show up in the video and audio source boxes. Give it an appropriate name in the output file box which reflects it is the first file, say video1.mpg. Now click on the load button and choose a DVD template, PAL if you use the PAL system, NTSC if you are in a region 1 country. Now click on setting. Click on the video tab and at the bottom of the window you will see "motion search precision." Choose "high quality slow." Close out the setting window and start encoding. The result will be a DVD compliant file. Now do the same thing for your next file giving it the name video2.mpg. When you are finished merge the files in the right order with the merge/cut tool. Let us know if that works.
  7. ook cheerz, i will now attempt that and wil get bak to u and tell u how it goes !!
  8. just tryed to open the avesque file from my svcd and it says file not supported? yet another problem !! y cant it just work for me grrr !! help plz
  9. If you have installed the mpeg2 plugin for TPMG go to the environmental settings in TMPG and make sure the plugin has a priority of at least 1.
  10. for some reason i cannot get the mpeg 2 plugin to work? read my post in this section called guide?
  11. Try this guide instead;https://www.videohelp.com/mpeg2tovcd.htm. Download the tools needed from the links in the guide. Follow the directions for making a DVD. See if that helps.
