Sorry for being a complete noob, but I've only just got a burner.
I'm trying to convert back from DivX format to something I can write to DVD with minimal loss during the conversion. I've read several DivX -> SVCD/VCD conversion tutorials, but I've not been able to make the leap in knowledge to get to the point were I can perform the process and write to DVD, or more o the point, multiple DVD disks.
So far I've used VirtualDub to extract the audio to a WAV file, then moved to TMPGEnc, using the original DivX as Video input and the extracted WAV file as the audio. I then get TMPGEnc to produce the m2v & mp2 files. I can even get to the point of encoding in DVD format (VIDEO_TS etc) by any of many routes (IfoEdit or others). I can then create a sinlge DVD (DVD2One or DVDShrink), but that often means further compression. However, the problem I can't grasp is when and how I need to split the materials such that I can create a multi-DVD movie.
At the moment I can get the material to the point of being in DVD format, but the data is too large to fit a single disc. How do I split it? As an example if I started with a single DVD-9 disk and ripped all the files, how would I go about writting it all to multiple disks (I'd like to keep the quality and content, so I don't want to shrink)? There doesn't seem to be a tutorial on this anywhere.
Thanks in advance for any replies.
Akwa
dvd2one does a nice job. try it to see if it's acceptable
This is so much fun!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
