I am still sort of a newbie but have been using tmpge for some time. I upgraded to 2.5 and now everything i try to do I get an error that states "can not load the p3package.dll". In common problems with the tmpge it states to make sure all files are unzipped and create a shortcut to open tmpge.exe. I am not sure what to do. Nothing seems to work. Can someone please help.
Open windows explorer.look at the directory were you put Tmpeg,is the P3 listed in the directory. If it not then re-install Tmpeg.
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 18:55 -
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
