HI ALL,
I HAVE 2 VCD DISC'S, I CONVERTED THEM TO MPG USING ISOBUSTER, STARTED UP SVCD2DVDMPG+ & authored 1st both & then only 1 in case that would help. within 10 minutes of coding the audio it crashed with a xp splash screen saying that besweet.exe had crashed. I've tried it a couple of times with the same outcome. Without besweet the authoring completes.
Just some background, i'm using the newest beta version of besweet, which is maybe the problem, & unzipped it in a folder below svcd,etc. if anyone has an idea or altenatively besweet. v1.5b17, let me know.
thanks in advance.
emtec.
did you name the folder besweet in the svcd2dvdmpg+ directory ?
recording from a cam in front of stage
By smartel in forum AudioReplies: 5Last Post: 7th Jul 2011, 08:45 -
At What Stage Do I Convert NTSC DV to Burn PAL DVD?
By Dubinvero in forum Video ConversionReplies: 4Last Post: 5th Oct 2010, 18:03 -
XP chkdsk stops at 56% on stage 4 of 5...
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Jul 2009, 00:11 -
editing stage question
By ht0160 in forum EditingReplies: 3Last Post: 2nd Jun 2008, 11:04 -
Capturing AC3 - Stage Two
By Nelson37 in forum AudioReplies: 2Last Post: 11th Nov 2007, 09:01
