I'm using Ulead DVD workshop to author a SVCD i want to burn all the video is already in SVCD format all i'm using Ulead for is to make menus etc. after i make them and try to burn it to DVD it wont let me i get the message "You need a CD-RW to burn a SVCD. Movie factory does the same thing what can i do?
I tried DVD Lab and my videos had no sound.
I keep talking about NeoDVD Plus which to some is not fancy enough however it always works fo me at least. Anyway NeoDVD will input AVI, dv, mpeg (svcd), mov, wmv, and VOB files and make a set of DVD files plus burn the files for you. This is not a high end program but it flat out works, is simple and user friendly (trust me I tried a lot of the low to mid end programs and this one actually works). You can read about the program here and no I don't work for them.
http://www.mediostream.com/products/neodvdplus/index.html -
Of course not. You can always convert the SVCD video to DVD format and burn it with Nero.
Hello. -
I did what the guide said and the video has little blocks in it on the right hand side i noticed that if i use DVD Patcher and put back the resolution of 480 x 480 that the blocks leave.
Any ideas? -
You could give DVDLab a try
It will let you create a DVD from a SVCD
The catch is that there are probably some players that the disc wont work on
phibertron
the sound in my converted videos IS there, but some programs wont play it?
By extent in forum Video ConversionReplies: 8Last Post: 30th Aug 2010, 16:38 -
Copy to DVD suddenly wont burn DL
By Yorel in forum DVD RippingReplies: 4Last Post: 25th Apr 2010, 21:42 -
Burning programs to burn multisesscion of photos on DVD-R
By better life in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2008, 07:29 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 22:39 -
My HP DVD Writer 840x Wont Burn !?
By ticotaz in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Jan 2008, 05:23
